Do you guys use frame limiter to avoid V-Sync taking over from G-Sync mode on older games when your PC copes just fine and would be able to generate 500fps if allowed?
Does the frame rate cap improve on input lag/latency on standard G-Sync On + V-Sync on + application V-Sync Off setting in this scenario?
