G-sync question
5 Jun 2016
I will be shortly be purchasing my first G-sync monitor and I have been doing a bit of research on how it works. It is advised that you use G-Sync & V-Sync together (vsync set to on in NCP). If the framerate goes over the G-sync range, 144hz/fps then Vsync takes over to eliminate tears.
Now at this point where the frames go over 144fps, is there any stutter or pause when regular vsync takes over, or is it a smooth transition? The same question applies to when the frames drop back into the G-sync range under 144hz/fps, is it noticable?
Thanks in advance.
No noticeable transition around the native Hz. You can try using FastSync instead of V-Sync to reduce latency but that can have a noticeable transition and/or stutter in some cases.
