Just trying to work out if I have a faulty monitor. I've been getting varying results with gsync, and recently noticed micro freezes with it enabled in some games (amongst other little problems).
Currently I have it set via NVCP:
Global Settings V-Sync on
G-Sync Enabled
For some games, such as CSGO I've set a custom profile to disable v-sync (which works). The problem is, particularly in CSGO I'm getting micro freezes of 1-2 seconds randomly but consistently.
What I've noticed recently, that I hadn't noticed before, is starting any game using Gsync my monitor flickers between graphical glitch screens that resemble a faulty gnu artifacts. These screens can flicker for anywhere from 1-3 seconds. In particular I notice it when starting CS:GO or StarCraft 2. It's similar to running games at a non native refresh rate, albeit in this instance there are colors and distortion over the screen. I can resolve this instantly by disabling G-Sync.
So I wanted to work out if this graphical gltching is unique to my monitor (AOC G2460PG) or if it is something noticeable by all users of GSync.
So if someone can copy these settings and test with CSGO I would appreciate it!
Nvidia Control Panel use 3d settings. Global Settings set to VSync On
Create a profile for CSGO. Set VSYNC to OFF.
G-Sync Enabled
Disable V-Sync ingame CSGO.
Fire up the game and pay attention to any weird flashing/graphics on startup. They also appear when alt tabbing. Also noticed in StarCraft 2 the same thing.
G-Sync Enabled
G-Sync Enabled
