 - 12 Jul 2012
Basically i'm buying this board
http://uk.gigabyte.com/products/product-page.aspx?pid=4482#sp
It basically says about the DDR memory
Support for DDR3 3000(O.C.) / 2933(O.C.) / 2800(O.C.) / 2666(O.C.) / 2600(O.C.) / 2500(O.C.) / 2400(O.C.) / 2200(O.C.) / 2133(O.C.) / 2000(O.C.) / 1866(O.C.) / 1800(O.C.) / 1600 / 1333 MHz
Anything above 1600mhz says O.C, i presume thats overclocked.
I plan to use 2 x 4GB sticks, does anything over 1600mhz need to be overclocked in the bios, its just i aint familiar with any type of overclocking as ive always run stock systems. Whats best to do, as an example would their be much noticeable difference between 1600mhz and 2133mhz ?
Its just i could use these
http://www.overclockers.co.uk/showproduct.php?prodid=MY-039-AR
or these
http://www.overclockers.co.uk/showproduct.php?prodid=MY-044-AR&tool=3
I just chose them as they seem to go with the mobo colour scheme, not familiar with Avexir as a make.
or these
