G27 calibration issues
26 Oct 2013
Leicester
Hi guys,
When I plug my G27 in, the calibration begins but then stops at the same point every time. The light on the shifter also stops flashing and just turns off at this point, so seems to completely stop working. Opening the menu for the wheel in Devices and Printers seems to help and it fully calibrates, yet when I exit the menu it just switches off.
In a laptop it calibrates just fine, the laptop running Win7 and desktop running Win10. I am led to believe it is a driver issue, though it could be random power issues also.
Anyone have any ideas?
Win10 is set to NOT automatically install drivers for stuff.
I had a similar issue a while ago with my G27 in one of my Win 10 pc's . Nothing but a fresh install of Win 10 fixed it. Was very annoying.
I just did a fresh install, it was a reinstall of Win10, previous install worked just fine, after the reinstall it isn't working anymore :/
there was a win 10 update that caused issues with logitech wheels recently.
also nvidia geforce experience can cause issues if you play through that.
make sure its in a usb 2.0 port and is actually showing up as a g27 in the lgs. make sure you use LGS 510 x64 and reinstall with wheel plugged into a usb2.0 port.
I have no rear USB 2.0 ports, only the front of the case ones
I will try reinstalling with it plugged in again, however in lgs the wheel won't show up as it dies half way through calibration
Same thing happened to mine.
Turns out there is a sensor shaped like large disc inside which had a hairline crack in it.
Strangely the first generation of G27 had these discs made of metal but the more recent batches were made of plastic.
Luckily mine was under 2 years old so after contacting Logitech they replaced the entire unit straight away.
99% sure this isn't the case as it calibrates correctly on my laptop, so must be driver related
