- 22 Mar 2009
- Cornwall
dont want to wc as we have 2 kids that like to pull/push things they aint supposed to, and the pc is in the front room, so aircooling is only option. is 4-4.2GHz achievable?
i dropped it down to 1.2 and it was stable, just wasnt happy with temps so dropped to 3.7GHz and its ok, so will wait til the new case comes next week
is there much difference between 3.7-4GHz?
Is your cooler good enough mate? i bought a AC 7 pro for 20 quid and it took me 3 times to mount it right as temps were all over the place. Make sure you have a decent air cooler as the chips get hot.
a lot volts for 3.8. my core i7 920 which is not a DO does 1.25 for 3.8
This was just a suggested starting point that was posted elsewhere in the forum.
and whithout your help my clock would still be 2.66GHz so im very greatfull.
just need the new case to turn up so i can see if 4GHz is achievable![]()
any ideas how i can speed my ram up to nearer its 1866MHz?
Increase the memory multiplier, that inturn will increase the memory frequency.
You will also need to increase the Uncore freq to 2xmem freq +1
eg mem @1600hz
uncore 3400hz
ok kool, will any voltages need changing?
