GA-K8VNXP wont boot and strange beep code
18 Oct 2002
Southampton
Morning all,
I picked up an old system for my mother-in-law so she can 'check emails and word process' etc. You know the score.
The problem is that the system doesn't boot.
It's a gigabyte GA-K8VNXP with a gig of crucial ram, a GeForce 4 and not much else to remark on.
For a couple of weeks the machine would turn on, spin up the drives but not boot / post. Nor did it beep. Then suddenly last night it started to beep.
It does 1 long beep. Long pause. Then 1 short, 1 long. Long pause then just loops doing 1 long + pause. I can't find what this means.
No and then it will stop doing this and just do long beeps in a loop.
I've found that if I remove the Ram from the system then it will just do long beeps all day long. I know this suggests the ram is knackered but I've swapped it out for other stuff with no luck. Also tried putting just 1 stick in all the slots individually. No luck.
Any suggestions on what I can try next? (Apart from scrap it?) :)
Thanks.
a bit of a google seems to suggest that the fact the beeping loops indicates its a memory error, but cant find an exact match for your beep code, have you got any other RAM you can try? as the sticks you have used may be both dead.
Further to that i think the mobo might be knackered... but dont quote me
Cheers Peeps, especially Deuce. I've already tried it with other Ram, and BIOS resetting.
Starting to think the motherboard is ka-put.
Cheers.
