I have completed an upgrade with i5 on a GA P55A UD4. It is running absolutely fine but at first start up it always hangs at Windows 7 splash screen and I have to power it off. Usually it starts ok after that and runs all day even with reboots etc.
System powered by OCZ GameXStream 600w PSU (From previous system). (BoughtJune 07 from OCUK)
i5 750
OCZ Gold Low Voltage 1600 4gig
Win 7 64
2 x old 8800GT's in SLI Latest drivers (Not ones that fry your card!)
No other cards
Stock settings EXCEPT ram set to 1333 and 1.6v and QPI to 1.21 as per specs (actually specced to 1600). Many sites suggest this. "Optimised" defaults seem to load ALL ram to 1066 no matter what it's speed. Memtest completed at these settings.
PSU SHOULD be adequate according to Antec PSU calculator (380W minimum)
Latest f9 BIOS
Run Memtest 86+ for 10 passes witout incident
Tried one 8800GT on its own in primary slot. No improvement. Will try other 8800GT to eliminate Graphics cards as problem.
Have to wait till next morning every time change anything as once it starts it runs fine.
Very occasionally get a BSOD 9c Machine_Check_Exception which doesn't help much. Mostly it just siezes before the little multicoloured window can form propely.
Tried tweaking CPU voltage up a bit. Started crashing Assassins Creed II after that even tho the voltage was only 1.25 from 1.23! Back to defaults.
After that will have to buy a PSU to try and poss hard drive with fresh install of Windows. All costs which may well be unnecessary
i5 750
Win 7 64
No other cards
Latest f9 BIOS
