GameMax Mid Tower Gaming Case with Tempered Glass Side, Mesh Front | GMX-F15M
The all new GameMax F15 Mid-Tower is a chassis designed to suit all builds. The F15 has interchangeable front panels, you have the opportunity to purchase the F15 either with a tempered glass front panel or with a full mesh front panel. (Each sold separately).
The F15 comes with exceptional cooling, included is 2 x 200mm ARGB fans at the front and 1 x 120mm ARGB fan at the back, with a further two fans been able to be fitted at the top of the chassis and on the PSU shroud.
You can connect all your fans to the pre-installed ARGB hub allowing for stunning lighting effects and an easily sync any further fans you choose to mount. You can also sync all fans to a compatible motherboard using the included 3 Pin AURA and VDG connectors. Please note the hub can connect only six fans.
The left side panel is made of 4mm tempered glass allowing the user to show off their internal components and show off the light coming from the 3 ARGB fans.
The I\O panel located on the top gives you easy access to the 1 x USB3.0, 2 x USB2.0 and HD Audio (Headphone and Microphone), allowing for connection to a variety of different devices. The chassis supports GPUs with a max. length of 365mm and CPU coolers with a max. height of 165mm.
In line with the GameMax ethos this case offers style, performance and the ultimate experience.
Compatible with the Following Fans
The GameMax F15 is compatible with the following fans:
The GameMax F15 is compatible with the following hubs:
- GameMax Mirage Dual-Ring Rainbow RGB 120mm Fan
- GameMax Mirage White Fins Dual-Ring Rainbow RGB 120mm Fan
- GameMax Razor 120mm Rainbow ARGB Fan
- GameMax Velocity 120mm Rainbow ARGB Fan
- GameMax ARGB 3 In 1 Kit
- Spectrum ARGB Hub
- GameMax ARGB Fan Hub
- F15 Range - The F15 is available in either a tempered glass or mesh option. The tempered glass front panel enables the perfect blend between aesthetics and performance, or the F15 is available with a full mesh front panel enabling direct airflow.
- Motherboard Sync - You can now take your colour customisation to new levels with the included ARGB motherboard connector, simply connect the 3 Pin to a compatible motherboard and you can use the mobo software to sync your fans the way you like.
- ARGB Hub - The F15 comes with a hub included and can connect to 6, 3 Pin or 4 Pin fans, from the hub you can control the colour mode, fan speed and LED speed. The hub comes with an AURA and VDG connection. Compatible with ASUS, MSI and Gigabyte RGB Fusion.
- RF Remote Controller - As well as been able to control your fans from your chassis using the built in hub and 3 Pin AURA connector, you can control your fan speed, LED speed or colour mode without any fuss using the RF (radio frequency) remote control. Using the remote control gives you easy access to 5 pre-programmed colour modes and several different colour modes.
- Water-Cooling Support - The front supports a 360mm radiator, a 240mm radiator can be mounted at the top and on the PSU shroud and a 120mm at the back of the case.
- Tempered Glass - A full left side tempered glass panel has been included allowing the user to show off their build and the glow from the ARGB fans.
- Vertical & Horizontal GPU - The F15 offers vertical or horizontal graphics card mounting, allowing you to be flexible and adjust your build to suit your needs.
Anyone else got one of these? Currently can be had for around £60 online.
They look pretty much like a Cooler Master H500M with some extras included.
Tempted to grab one, but at the same time never heard of GameMax and it is not like I need it as what I have more than does the job, just a case of trying something new without being wasteful.
