** Gamers Bundle for Xmas Stocking Fillers ** Mouse and Pad
8 Sep 2003
150 yds from OcUK
*** *** Steelseries Kinzu Optical Gaming Mouse & QcK Mini Gaming Pad @ £19.99 inc VAT *** ***
Mouse
SteelSeries Kinzu was developed in close cooperation with professional gamers to set new standards for performance in optical mice. The Gaming Grade image correlation sensor has been optimized to improve stability and eliminate jitter. The CPI settings are based upon those used and recommended by professional gamers.
This compact ambidextrous mouse operates with 9375 Frames Per Second at movement speeds of 50 Inches Per Second and supports customizable polling rate (between 125-1000Hz) with as little as 1 millisecond delay between the mouse and the computer. SteelSeries Kinzu is compact, lightweight, optical and is in a league of its own when it comes to reliability and stability.
- Adjustable DPI up to 3200
- 9375 FPS
- Acceleration on/off toggle via software
- 1ms response time
- Slip resistant coating for superior mouse grip and control
- 2 Year Warranty
Gaming Surface
The SteelSeries QcK-line of mouse pads are made of high quality cloth material, providing a precise and consistent glide. All mouse pads feature a specially designed non-slip rubber base which prevents the pads from sliding, no matter what surface the mouse pad is placed on. The mouse pads differ in dimensions and thickness, but not in precision, glide or quality. As some of the mouse pads are very large, we highly recommend measuring how much space you have on your desktop before ordering.
- Ideal for low sensitivity mouse settings
- Compatible with all mice
- Specially designed non-slip rubber base
- Dimensions: 250mm x 210mm x 2mm
Only £19.99 inc VAT. Saving you over £22 on the RRP price.
ORDER NOW
