Permabanned
- 28 Sep 2018
https://www.youtube.com/watch?v=KPaSEGe6ML0
Wanted to make a new thread as it's good to a see a non asetek and an inexpensive cooler that takes the crown. At the price this comes in at, it's virtually a no brainer unless RGB is key priority for you. Looking forward to seeing their teardown next.
I've mentioned my fondness of the 360mm version here a few times. I also made a comparison to another powerful AIO here: https://www.reddit.com/r/intel/comments/dti3jg/alphacool_lt_360mm_vs_arctic_freezer_ii_360mm/
Overall, I have and continue to highly recommend this to anyone with a high end chip and is looking to push it. As noted by GN, it's *VERY* quiet also when delivering close it's max performance so you don't have to turn it into a jet engine to get performance out of it.
@MartinPrince tagging you since you were interested.
One thing not mentioned by GN that is very important to me. The unit simply works off your CPU/AIO header on the mobo. It does not need any bloatware to make it work.
