Man of Honour
Thanks, what did you have before and how have the temps changed?it’s a 4790k (old I know)
idles at around 29. Pushed when gaming it goes to mid 50s.
Thanks, I might give one a go to replace my H220-X and just accept that I've got a ~5+ year use out of it. I'm still undecided over the 280 or the 360 so may end up getting both so I can test for myself.@MartinPrince https://www.youtube.com/watch?v=ZQRwn-lecnk tear down. The impeller diff and materials vs asetek is impressive. Pretty much a great unit all around.
Like the look of that cooler, I just have an air cooler at the moment, not sure if it's worth the money moving to such an AIO for a 3700X considering It can't overclock.
Suprised it's running that hot, I'm using a wraith prism on my r5 3600 4.2 all core OC @1.325v and even spamming cinebench it never goes over 67c.Recently purchased the artic freezer esports (air cooler) and I’m hitting 77c on bannerlord while streaming
Your CPU will boost higher and hold the boosted speeds longer the better the cooling you have, so it depends on what air cooler you have and what temperatures you are getting. With a low TDP chip like the 3700X the performance difference is unlikely to be huge but to some people getting the most performance possible out of their system is worth the money. Again depending on your existing cooler this cooler may end up being quieter.Like the look of that cooler, I just have an air cooler at the moment, not sure if it's worth the money moving to such an AIO for a 3700X considering It can't overclock.
In which case I would suggest the upgrade. From what I can see the Evo 212 has direct contact heatpipes which are not ideal for a 3700X due to the main heat source being off Centre. In my opinion you would be better off with a cooler that has a base plate to more effectively dissipate the heat either this one (Freezer II) or a different air cooler, most of the best performing top end ones have a base plate rather than direct contact.I have a Evo 212 cooler.
Might invest in this cooler in that case, there is a 240 version what's the difference?
Edit, I get it now, the radiator size.
There is a 360 , how much more effective than the 280 would that be given the extra fan
Can I suggest you watch the videoAlso how can the 280 be quieter than top air coolers if the fan RPM is higher? Or wait, maybe they didn't show the coolers with max fan RPM in the reviews
I did. So the 280 might be better than the 360?Can I suggest you watch the video
