Games freezing with 100% disk usage
18 Jan 2007
Land of the Scots
I've had an issue with games freezing for up to 10 seconds at a time. Made sure I had task manager up and it shows that at the time of the freeze one of my SSDs is at 100% usage. It's not even necessarily the disk that the game is installed to and is not my OS drive but is always the same drive.
Any ideas?
I had a very similar issue with the MSI auto updater tool for the motherboard, removing this set things right. IT would periodically spike to 100% CPU usage, and was bloatware anyway, so in the bin it went!
Thanks for the replies guys, I have been taking a closer look today, according to task manager there is no actual transfer but active time is at 100% for the freeze period.
What program is responsible for the ssd usage?
I haven't been able to catch anything in processes tab (having trouble making it freeze today) but not sure I will based on the above.
How much RAM do you have?
16GB
Edit: Upon closer investigation device manager was showing that the driver for that drive was for a 240GB drive (which I used to have in my system) rather than a 480GB drive. I've reinstalled the drive and will see how that goes.
Hopefully that does the trick. Worth double-checking Disk Management to see if that drive has ended up marked Active or Page File or similar, somehow
Resource Monitor > Disk > Disk Activity, is better for spotting the worst write-to-disk offender.
