Yea...I had a go to try the fit the budget but pretty much got the same components as you, but case could get this instead of getting the Antec 300 to save £10:How does this look?
nothing wrong there.
but why ultimate?
ll monitor? Pretty sure there are better monitors for that price...or even cheaper.You really should get the Arctic Cooling MX-3 Thermal Compound to use with that CPU cooler. It's can potentially lower the CPU temperature by 10-15C than the generic Thermal Compound used on the CPU cooler. With lower temperature, it will give you more overclocking headroom.
Also, any particular reason for choosing that Dll monitor? Pretty sure there are better monitors for that price...or even cheaper.
You can get a 24" BenQ monitor for £142:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-030-BQ&groupid=17&catid=510&subcat=
Ah didn't realise that. I thought it's the same as the old Arctic Cooling Freezer 7 Pro...which I am pretty sure is with just generic thermal compound. Personally speaking though, I don't like pre-applied paste too much, as it is using the 'spread' method, which is commonly known to trap air-bubbles...That cooler comes with pre-applied MX-2 (see product page) so I don't think 10-15 degrees is going to happen.
