Hi All,
I'll be building a gaming pc from scratch and have a budget around £600
I want to be able to play Overwatch, minimum system specs are here:
https://eu.battle.net/support/en/article/7636
I have a mouse, keyboard, monitor etc that I can use so it is just the case & all components.
What parts would you recommend? Would it be better buying a pre-built PC at this budget range?
Also, should I hang on till mid June before I purchase a GPU in the hope that prices will drop due to the new Nvidia cards?
Cheers
Cheers
