Gaming build
Looks good, apart from the GPU obvisouly. However for the price, I would just get the cheap GTX460 or the HD6850, which are actually cheaper and better.
remember that the DF10 max graphics card length is 11.5'', which is the length of the reference design HD7970.
And of course the AG15 promotional code for antec case / psu combo.
Well no one told me really it was just a logical progresion , couldn't afford the 560 so thought it was the next best thing.
The next question is, given I've never built a system from the ground up, though I have played round inside boxes before, anyone got any good 101 linkage to make sure I've got a clear idea of all the stages involved ?
Cheers again for the help guys ;)
My top tips:
  • If it's first build recruit Pro PC building chum who you can leave to install Windows 7 why you have a chill!
  • Read the paperwork - motherboard manual especially & case instructions
  • Dispatch flat mates/family members to shops, day out, holiday
  • Nice large clean table top with desk lights and containers to put small parts in stop 'em getting lost
  • Collect small screw drivers, torch, anything you need, must be clean for electronics
  • Extension lead for pluggin in, monitor, ideally wired mouse and keyboard
  • Once built I recommend putting all the instructions and paperwork in a folder for reference purposes
  • I keep all the boxes so in the future if you need to RMA/sell kit on ebay they can be delivered well cared for
Phew! Good luck ;)
If I go for the ATI option I can buy a cheaper version of the mobo without SLI support so I'd have an extra £50 to spend on my ATI GPU, which would you reccomend ?
Also thanks for the build hints and tips sounds like good advice :)
Think I'll stick with my mobo choice and buy the card you linked, as that gigabyte isn't gen 3 and I like the idea of the ASUS software suite for easy OC'ing as it's not something I've done before.
The Gigbayte includes Eazytune6 to overclock.
As for Gen3, you need a Ivybridge CPU, also test of the new ATI 7970 card at PCI-E2 vs PCI-E3 show sod all difference.
Fair enough didn't know that. Maybe I'm being stubborn here but think I'm still gonna go with the Asus more a niggling sense of 'you get what you pay for' than anything else really.
Thanks for all the help Stulid mate, would be nice if I could buy you a pint for all your help, suppose you'll just have to settle with me saying I appreciate all you (and everyone else) has done.
I like the Gigabyte Z68XP-UD3P. Main difference with the Z68XP-UD3 is VRM power phase 6+1 versus 12+1, and dual PCB layer (ultra durable).
Asus should be a good board, although people complained about their QA and reliability.
