Gaming Build
10 Nov 2014
Evening all.
Would it be possible to get to comparable builds please? What I'm looking for are 2 builds to compare. One costing around £1000, the other £1500. If you could then add the positives and negatives of spending the extra £500 so I can make a judgement on whether it's worth spending the extra.
Ideally the system can play and record the latest games. 16gb memory would also be ideal. I've also set aside £500 for keyboard + Mouse. Windows 7. Triple screen monitors if that's within the £500. Otherwise 1 is fine.
Thanks for the help :)
Hi,
I think I will have a go at this:cool:
So is this OS+keyboard+mouse etc for £1000 and £1500?
Because here is a £1500 spec for just the tower only,
YOUR BASKET
1 x Gigabyte Z97X-UD3H-BK - Devil's Canyon Core i7 4790K CPU & Motherboard Bundle **£35 Saving** £365.98
2 x Gigabyte GeForce GTX 970 WindForce OC 4096MB GDDR5 PCI-Express Graphics Card (GV-N970WF3OC-4GD) £275.99 (£551.98)
1 x Kingston HyperX Beast 16GB (2x8GB) PC3-19200C11 2400MHz Dual Channel Kit (HX324C11T3K2/16) £129.95
1 x SuperFlower Leadex GOLD 750W Fully Modular "80 Plus Gold" Power Supply - Black £99.95
1 x Corsair Hydro H105 Extreme Performance Liquid CPU Cooler (CW-9060016-WW ) £89.99
1 x Phanteks Enthoo Pro Mid Tower Enthusiast Case with Window £89.99
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £79.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £61.99
1 x LG GH24NSB0 24x DVD±RW SATA ReWriter (Black) - OEM £13.99
Total : £1,493.40 (includes shipping : £8.00).
Free delivery with this PSU - http://forums.overclockers.co.uk/showthread.php?t=18630207
Motherboard has a 5 year warranty and free upgrade within 3 years - http://forums.overclockers.co.uk/showthread.php?t=18631511
And here is £1000 spec,
YOUR BASKET
1 x MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £269.99
1 x Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle **£14 Saving** £252.58
1 x TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLD316G2133HC11ADC01) £129.95
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £39.95
1 x Raijintek Themis Evo Professional CPU Cooler £27.95
Total : £1,013.93 (includes shipping : £8.00).
Both these specs are SLI ready and indeed the first one is SLI.
And here are my recommendations for the other parts:cool:
YOUR BASKET
1 x Acer XB270HA 27" G-Sync 144Hz Gaming Widescreen LED Monitor - Black/Red £379.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £77.99
1 x CM Storm Devastator Gaming Bundle - USB Keyboard & Mouse £29.99
Total : £501.47 (includes shipping : £11.25).
G-Sync!!! must have that for this budget!:)
Eliminates VSync tearing, lag and generally awesome for gaming;)
Right £1000;
YOUR BASKET
1 x Inno3D GeForce GTX 970 OC 4096MB GDDR5 PCI-Express Graphics Card £249.95
1 x Avexir Core White Series 8GB (2x4GB) DDR3 PC3-17200C11 2133MHz Dual Channel Memory Kit (AVD3U21331104G-2CIW) - White Light £69.95
1 x BitFenix Ronin Tower Case - Black £69.95
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £59.99
1 x Raijintek Themis Black Heatpipe CPU Cooler PWM - 120mm £19.99
Total : £992.78 (includes shipping : £12.50).
That has 8GB RAM which should be enough for recording and playing games. However, if you really wanted 16GB
YOUR BASKET
1 x EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply £89.99
Total : £969.38 (includes shipping : £12.50).
But this only has an i5
Here's an attempt for 16GB RAM + i7 at the £1000 mark
YOUR BASKET
1 x Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £257.99
1 x Gigabyte Z97P-D3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £61.99
1 x NZXT SOURCE 340 Midi-Tower Case- Black Window £54.95
Total : £991.79 (includes shipping : £12.50).
Obviously not an SLI ready motherboard, so no need for a large PSU here
£1500 ------------------------------------
YOUR BASKET
2 x Inno3D GeForce GTX 970 OC 4096MB GDDR5 PCI-Express Graphics Card £249.95 (£499.90)
1 x Crucial MX100 512GB SATA 2.5” 7mm SSD + 9.5mm Adapter CT512MX100SSD1) £154.99
1 x EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply £109.99
Total : £1,512.37 (includes shipping : £8.00).
or single GPU setup;
YOUR BASKET
1 x Inno3D GeForce GTX 980 "Herculez X3 Ultra" 4096MB GDDR5 PCI-Express Graphics Card (N98V-1SDN-M5DNX) £399.95
Total : £1,412.42 (includes shipping : £8.00).
Which has scope for future SLI (compatible motherboard and PSU)
10 year warranty on the PSU also - insane! :o
Could add some bling into the builds with braided cables - http://www.overclockers.co.uk/productlist.php?groupid=2833&catid=2838
and LED strips
Nvidia cards take advantage of shadowplay which can record gameplay with almost no lag which is nice :)
Extra £500 gets you an i7 + 16GB RAM, and dual 970s or single GTX 980. However, the dual 970s are overkill for 1080p and are better suited for 1440p/4K. The 980 won't struggle at 1440p by itself either
Peripherals;
YOUR BASKET
1 x Acer K272HUL 27" Widescreen LED Gaming Slim Bezel Flicker FREE Monitor - Black £299.99
1 x AOC G2460PQU 24" Widescreen 144Hz 1ms Gaming LED Monitor - Gunmetal £193.99
1 x CM Storm Quickfire XT - Mechanical Keyboard - Brown Switch £68.99
1 x Zowie FK1 High Performance Gaming Mouse £49.99
Total : £712.37 (includes shipping : £17.85).
Has both a 1440p and 144Hz monitor there, so you can choose :) Some prefer 144Hz, some prefer higher res. Also, 3 monitors can be done
YOUR BASKET
3 x Samsung SyncMaster S24D390HL 24" Widescreen Slim Bezel LED Monitor - Black £113.99 (£341.97)
Total : £548.53 (includes shipping : £8.00).
Mouse + keyboard are subjective so i suggest you try some out or something
A good choice, what a beast.
Remember to get that board registered for the extended warranty and that upgrade offer:)
