Depends how much "bang" you have. And which GPU.
But those fx-8320s give you a lot of CPU for the price
Yes they look good for the price, 8 core too. My Brother is looking for a nice gaming build that won't cost him a lot of money. Thanks for the reply![]()
SourceHexus | 8th Aug 2014 said:AMD set to slash FX CPU pricing on September 1
Said FX-9590, currently retailing at £225, will drop to around £175 on September 1, thereby competing against the Core i5-4690K. AMD says the FX 9590's greater multi-core ability will give it a clear and obvious lead for power users.
AMD will introduce three new FX 8-series CPUs at the same time, with two running at 95W, while the price of the popular FX-6300 is to drop from £80 to around £70.
I wonder what the difference between the 8370 and the 8370E is... Same clock speeds with lower TDP? Implying that it uses lower voltages? Would be good for overlocking in that case![]()
SourceTechpowerup | 23rd August 2014 said:AMD FX-8370 and FX-8370E to Launch on 2nd September 2014
AMD is planning to launch its next performance-segment CPUs alongside its Radeon R9 285 graphics card; the FX-8370 and its energy-efficient variant, the FX-8370E.
Based on the 32 nm "Vishera" silicon, the FX-8370 is an eight-core socket AM3+ processor, featuring out of the box clock speeds of 4.10 GHz, with TurboCore frequencies of 4.30 GHz.
The standard variant features 125W TDP, while the FX-8370E features 95W. The two will sell at the same price-points as the FX-8350. The FX-8370E will sell at a slight premium.
