Gaming Laptop Help
17 Jul 2015
Hi
i need a little help finding a gaming laptop, my budget is around £600-£700 ish.
Not sure how good of a gaming laptop i can get for that price but the games i would
like to play on it are Guild Wars 2 and World of Warcraft, i play other older games
more then them but if it can run them games it will run my older games fine.
maybe one with with a 17" screen would be nice to.
Thanks for your help:D
  • Inspiron 15 - 7567 Gaming Laptop
    Processor: Intel® Core™ i7-7700HQ (Quad Core,up to 3.8GHz, 6MB Cache, 45W)
    Windows 10 Home (64bit)
    16GB (1x16GB) 2400MHz DDR4 Non-ECC
    1 TB SATA 2.5inch (5,400 Rpm) Hard Drive
    128 GB SATA Solid State Drive
    NVIDIA GeForce GTX 1050 Graphics with 4GB GDDR5 vRAM
    Software
    Intel Dual Band Wireless-AC 3165 802.11ac, 1x1, 2.4 & 5GHz + Bluetooth 4.2
    LCD Back Cover - Black (Non-Touch Screen)
    Battery : Primary 6-cell 74W/HR(Integrated)
    15.6 inch FHD (1920 x 1080) Anti-Glare LED-Backlit Display
    Internal UK/Irish Backlit Keyboard
  • Standard ShippingFREE
  • Outlet Price From£726.00
From the dell outlet is likely the best you can get whilst avoiding fleabay.
My advice would be to look at the Dell G3 gaming laptop or the HP Omen laptop at this budget, even then expect some sacrifices. Not sure if you’re a student, if so, don’t forget UNiDAYS or other such sites to get money off.
