ok, as said earlier..if you can sped 20 mins or so a day,you need to start posting to get to 1000 posts..for an example, there's a b650 tuf gaming wifi board and 7600 on offer from someone that's just upgraded to 7800x3d/b650e-e board he got on MM that will save you 120 over new..my view he still need to come down a little as he got a stonking deal on the 7800x3d package.
on other mktplace seen a b650 tomahawk board and 32gb 5200 ddr5 ram for £150(can always bargain as he hasn't sold it yet)..the mobo is £160 new so you're getting the ram for free and £10 off board..not the fastest ram, but it'll do and it's 32gb of it..or seen a b650 gaming plus wifi for £100, or a b650m aorus elite for 100...set of 32gb corsair vengeance non rgb 6000c36 for £60 so there is stuff out there
or seen whole pc...7600x cpu, b650M mobo, 32gb 6000 ram, 2tb m.2 ssd, ak400 air cooler, msi 850w psu and a 7700xt gpu...can't tell case but he wants 725...no takers so far so could probably put a bid in...he has receipts from buying the parts, and selling after 4 months as not using it
if you do find someone selling a 7600 cpu, it comes with a stock cooler so to start with, if money is tight, no need to pay extra to get another..just use the stock for awhile..it does the job
ssd, the g50 from OCuk i put above is cheap as on offer at mo and decent performance/endurance
psu( i never really skimp on this as powers everything, including all your expensive bit.. at the moment I'd go Asus tuf 850W 80 plus gold for £90. 10 yrs warranty, atx3.0 so has the connection for the new nvidia gpu's and it'll outlast the build and be good for the next one, and 850 is enough to power a 4080, so should be good for upgrades. the 750w psu is £10 cheaper to save, but might hamper new more powerful upgrades down the line
£250 will get you a 3070, a 3060ti closer to £200...just seen a strix rx6750xt triple fan card for £260(however selling it done a good job ceaning it, looks like new...no dust on it at all)
7600x...only seen one at mo for £140, 7600 for £120
so cpu 120 he's reduced already..offer 100
mobo and ram 150
1tb ssd 50..ocuk
psu 80/90....ocuk
gpu £250 (6750xt)
case 40
that'll come to £700 with a copy of windows(google how to get cheap)
too much can start lowering gpu...etc
gives you an idea
thermal paste if buying 2nd hand cpu...something like arctic mx5 or noctua nt h2(got and used both)...basically are long life pastes that are non conductive, so no chance of putting too much on and creating a short somewhere...paste good enought that once applied should last the pc lifetime or till you upgrade..nt h2 been used on my 5800x cpu for just shy of 4yrs no problem
mobo and ram 150
1tb ssd 50..ocuk
psu 80/90....ocuk
gpu £250 (6750xt)
case 40
gives you an idea
