Can you wait 3 weeks?Hello,
I'm looking for the best gaming PC with a budget of £2000, can someone point me in the right direction?
I don't have a clue how to build one I'm new to this so would prefer the whole package
For your budget, definitely.Yes I can wait until July if its more beneficial
A £2000 gaming base unit? You would be looking at 27" ~£400 (even more depending on quality/size/resolution) monitor to compliment it properly...I just need the Tower, i can pay extra for a monitor if its not loads more
@orbitalwalsh - can demonstrate a very tidy INTEL build - but keep it as a 'place holder' for comparison to that of the Ryzen 3000 (Zen 2) releases after the 7th and reviews. Then you won't suffer from buyer's remorse...Yeah £2000 gaming base unit, and a £400 27". Work your magic
You're off the leash Orbi
We have very different definitions of fun - I made the mistake of posting late on a Friday night. The skin on my forehead has only just started healing.Been mulling around the CPU threads as it's to much fun.
Yep - type the following:How do i bump it? do i just reply on the 7th? Thanks for both your time also
lolYep - type the following:
Oi! @orbitalwalsh - spec me a Ryzen 3800X/3900X build with the best bang for buck quality x570 (it will be a Gigabyte) and ~3600MHz memory plus high end GPU and quality 27" 1440p 144Hz monitor for £2000 (monitor not included in price). Or, i'll start breaking 360mm RGB AIOs...
*He'll soon turn up
*He'll soon turn up
Well, i can think of a couple of members who you will have strong opinions on this before their brain engages.HAHA - might have to start dropping random rumors for the heck of it now . wondering if i can spin a 4 core unlocked 10nm being released with the rest of the 10 core chips that are 14nm ... mmmmm
No way to address your, Dad!cheeky sod
OP - ^^^important when comparing - if you're confused we'll clarify.Roughly - Hoping for 15% uplift on Gigabyte/Aorus boards from Z390 - now dollor to Pound can effect this GREATLY . so what I'll do is had a higher model board then the one that could be chosen for x570 to get the price increase . So i've selected the z390 Pro Wifi to hopefully reflect X570 Elite price
*cough* navigate the CPU forum and read his teeny-tiny font posts *cough*cant say much on Navi RX 5700 without getting a slapped wrist , but everyone was hoping it would have been cheaper - all i can say on that bit
cheeky sod
VERY ROUGHLY ! was given a base of 15% increase for a vendor but having a feeling thats going to become what they wished... though I dont believe this **** about 60% rise from Z390 boards
Ryzen 3700x = $330 - convert to £ is £260 - add your VAT ( god i hope if this brexit thing goes through VAT will go back down to 17.5 etc lol) and you land at £312 !
Ryzen 3800x = $399 - £314 + VAT £377
Ryzen 3900x = $504 - £396 + VAT £475
New ryzen works out $21 per thread, Intel closets is 9900 non K at $27 ! ouch
My basket at Overclockers UK:
- 1 x Intel Core i7-9700K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM= £359.99
- 1 x Gigabyte Z390 Aorus Pro WIFI Intel Z390 (Socket 1151) DDR4 ATX Motherboard= £194.99
- 1 x Gigabyte GeForce RTX 2080 Gaming OC 8192MB GDDR6 PCI-Express Graphics Card= £709.99
- 1 x EVGA Supernova P2 650W 80 Plus Platinum Modular Power Supply= £94.99
- 1 x Team Group Dark Pro "8Pack Edition" 16GB (2x8GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit - Black/= £149.99
- 1 x CoolerMaster MasterBox NR600 ATX Midi-Tower Case - Black Tempered Glass= £69.95
- 1 x Alpenfohn Brocken ECO Advanced CPU Cooler - 120 mm= £29.99
- 1 x Intel 660P 1TB M.2-2280 PCI-e 3.0 x 4 NVMe QLC 3D NAND Solid State Drive (SSDPEKNW010T8X1)= £109.99
- 1 x AOC AGON AG271QG 27" 2560 x 1440 IPS G-Sync 165Hz Gaming Widescreen LED Monitor - Black/Red= £534.95
as a rough guide !!! ^^^^^
cases are down to what you like so hard to judge
TN Panel can save some cash as well. cant say much on Navi RX 5700 without getting a slapped wrist , but everyone was hoping it would have been cheaper - all i can say on that bit
Will Overclockers build this for me?
