Gaming PC Upgrade - Help required!
Hi again,
For a spec can you list clearly what parts you need? and a budget so the specs don't get to carried away:D
Hello again. Haha sure :)
I am looking to spend max £700-800 on the parts (at a push £1000 or so, but would need to wait a little longer for that), and for that, I require CPU, motherboard and RAM. The case is decided, I need no convincing there! But honestly, if you can't find me a good CPU, motherboard and RAM combo for £800, there is a problem ;)
Thanks. Cooling is fine, water loop just needs some tweaks to the pipes
Your water block has socket 1156/55 support ? which is the same as 1150.
Last spec,
YOUR BASKET
1 x Corsair Obsidian 900D Super Tower Case £299.99
1 x Intel 4820K 3.70GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74820K) £249.95
1 x Gigabyte X79-UD3 Intel X79 (Socket 2011) DDR3 Motherboard £169.99
1 x Patriot Intel Extreme Masters 16GB (4x4GB) DDR3 PC3-14900C10 1866MHz Quad Channel Kit (PVI316G186C9QK) £129.95
Total : £866.38 (includes shipping : £13.75).
The waterblock is an EK-Supreme Full Nickel block. Currently it's on my 1366 socket i7. I guess it probably just needs a new bracket to work. Will need to double check.
Thanks again stulid, those all look really ace!
