hi all I need some advice on how to keep rats and mice out of my garage
i have an up and over metal door and it has a gap underneath I suspect the rodents are coming in via this gap.
I have had a look online and seen some strips that fit under the door but with it being a metal door I am unsure which seal I would require and how to fit it exactly I would have thought u couldn't hammer a nail into metal? and as far as I know you need a particular type of drill bit and screw to screw into it.
any ideas which product will work? and which types of fixings do i need?
