Garage inspiration required!
30 Sep 2003
Norwich
Proper first world problem here but I'm soon to be buying a new house with a double garage and driveway parking for two cars without having to shuffle them round and/or back them down the length of the drive on to the road. So far so good.
I used to have a tandem garage (that I'd pretty much filled up) with a 3 car length single width drive to house a Leon, Polo and MX5.
Now, I want to keep my MX5 but parking it on the drive is not an option so can anyone give any advice (with pictures please!) Of how you can make a double garage work to both house a car and the whole wealth of toot that we have these days?
I'm going to need to house;
Chest freezer
5 bikes, bike racks and roof bars etc.
Garden tools inc mower, shredder etc.
DIY tools
Car tools and cleaning gear
Pressure washer
In other words, more than I can see fitting but before I list the car for sale I'm hoping that the good people of OCUK might be able to throw me a lifeline.
TIA :)
I built sheds for bikes, garden tools and equip etc so that I could keep the garage specifically 1 side to house the VW T2 and the other side for the lathe/pillar drill tool cupboards, TIG/fab bench etc.
Not a chance of being able to work in there, whilst having it full of house/garden clap trap.
Shed for storage is a good shout. Will need a bit of thought as to where but I think there is a corner where I could make that work. I'd probably want to limit that to garden tools and a bit of bulky storage though.
Easy, just build a storage area on top of the garage. I built a pool on top of mine, a storage area should be much easier.
A shed is probably a much better idea but there’s no fun in that!
The bigger houses on the development have a loft space in the garage. No idea how much it would cost to whip the top off and do similar. Or if I'd need planning permission to do it.
I need to also work out just how much the boarded out roof space is going to gain me over my previous flat roof garage. I think the answer will be - not much!
Do you have a picture of your current garage?
With it being a double I assume it's detached, and that it's an apex roof. My dad has just boarded out his double and stores loads of **** in there, although he only keeps one if his cars in there. I'd have thought the stuff you listed won't take up much space anyway, but you could store the bikes vertically on the wall, or maybe even hang them (not sure on logistics of that last bit though, obviously depends on weight of the bike and how spritely you are). Fwiw I've got a 10 by 8 foot shed (which is a tad small), but we store stuff like bikes and the lawn mower in there. Not sure if wood would be better than the metal ones as I've heard stories of metal sheds suffering from condensation.
I wouldn't have thought an MX5 would take up so much room in a double garage that you couldn't fit all that other stuff in.
You must have a LOT of stuff... A clearout might help?
Thanks for all the input.
I better not start posting photos as it isn't ours yet! But it is just your bog standard double with two roller doors. 5.9 x 5.8m according to our surveyor (aka my farther in law :p). He showed me some pictures of the inside today (estate agent didn't have a key when we did our viewing) and the roof is boarded out around the perimeter, should be handy for keeping roof bars etc. out the way.
Longer term I don't plan on keeping quite as much in the garage as I did at the previous place. For example there won't be a need to have a tumble drier out there. Likewise while we may need a chest freezer in there we will probably go for one half the size of what we had previously.
I did de-clutter the old garage when we moved so hopefully it will be OK. I guess the mental issue is two fold, I previously had two garage worth of space without a car in there so I'll effectively have half. Also our temporary digs has a single garage which is absolutely rammed BUT it does have box loads of stuff we can't house in the bungalow and the contents of our old loft. Once we move we should have at least double the usable boarded out loft space so that should help as well.
My main goal is to keep the space organised and usable. Fitting everything in and then having to do gymnastics to get to stuff isn't really an option. I'd also like to get a small workbench in there and get back to some of my hobbies (RC cars etc.) at some point but the latter feels like a bit of a pipe dream at this point!
Probably the biggest issue is bikes. I have 4 and the wife has 3. Two of hers really need to go but all mine serve an important purpose and are therefore staying ;)
I'll seriously consider a shed, if only to stick the gardening stuff in, but the house is a bit of an odd layout with the bulk of the garden out the front with the drive at the rear accessed via a private road. The front garden is screened off from the street though so a shed tucked in the corner shouldn't look too odd.
Chest freezer
DIY tools
Pressure washer
TIA :)
Just the 1 chest frezzer....wtf
Yeah first off put anything garden related in a shed somewhere else, don't want to clutter your garage up with garden tools, folding chairs and kids garden toys.
For bikes i put hooks up on the wall of my garage and lift them up there out of the way but i only have one sketchy old mountain bike, nothing fancy.
I'm lucky in that my garage is tall so i built a massive shelf to store all the other tat that you don't need often, it's 4.8m long by 1.2m deep
I've got my old Mini in one half of the garage which leaves lots of room left for getting another car in or whatever in the other 'bay' (saying that it's now filled up with trains but that's another story/problem..)
This is 7m long by 6m wide for reference:
AL9nZEWuX3KATYSOHKhNUXxz2zJQcot85w_65OM7UMFJs2F6CoRExc7ZP0XRaysUHy7_Hn5g7jSRt66OlqsT85rDE-SEEiRTA7JIE4I7RPw2hO-ZK5Xg13JtFg4LXEWePSQdCeQGtYilzsJOxMd1c20zmLw48g=w2306-h1297-no
Forgive me for sounding stupid but surely all you need is a road bike and a mountain bike?
I don't 'need' all 4 but they do have specific purposes;
Road bike - 100 mile sportive / dry summer ride machine
Mountain Bike - Forest trails, off road / mainly off road sportives
Gravel Bike - 50/50 on/off road sportives / winter or wet road rides / Bridleway exploring
Hybrid - An old hack for nipping to the shop etc. Soon to be kitted out with a kid trailer thing (another thing to store...)
Not too many dead bodies / road kill to store ;)
I have an almost identically-sized double garage to you and I keep all of the garden stuff in a separate outbuilding which helps massively. Looking at the garage from the front, I have racking along the full length of the right hand side. Along the left hand side I keep my floorstanding toolchest and a workbench of sorts. This leaves me the middle of the garage to park a car and be able to open both doors if needed (3.3m!) which means I can move about the garage to get stuff from the racks without too much risk of hitting the car with something. I don't have anything along the back wall of note because if I did I wouldn't be able to get the car in comfortably (4.7m long).
I would imagine if I had to swap my considerations for yours I'd put the bikes and freezer where my toolchest and workbench is and keep the garden/DIY stuff on the racking.
With it being 2 single doors you’re looking at car one one side and everything else on the other. (With a big double door you’d have the option to put the car in the middle with ‘stuff’ along both side walls). I’d be tempted to put some kind of partition down the middle. It’ll delineate the space that’s dedicated to the car (preventing the other stuff from gradually creeping into that area), protect the car from stray bikes etc falling on it and will give you more wall space on the ‘stuff’ side of the garage for putting things against.
That is a very good shout. I'm thinking of running heavy duty racking down the middle leaving just enough space to get in/out of the car. I'd then look to back it with ply or exterior MDF and maybe foam the reverse, just in the area I'll be opening the door. If I swap cars and need more space I can just shift the whole lot back a foot or so and if the car ends up getting sold I can shove the whole lot against the wall.
A single big roller door would be easier but as you say, the double does allow a dedicated car space.
Bike wise I'm considering a mix of wall and hoist storage, assuming I can get them high enough to gain a meaningful space underneath.
We'll be buying a new freezer so I'll get an upright instead of a chest to A) save some space and B) not end up with a cryogenically preserved pack of chicken thighs that get buried for a decade.
I'm starting to feel more positive I can get this to work without sacrificing a car!
