It should have minimal effect on your workshop - for mine it's just 4 screws fastening the backboard of the box to the wall, an 80mm hole I used a core drill head for to get the hot air pipe into the garage/workshop and a 6mm drill hole to take power out from a normal 3pin socket to the PSU. I just used a 3m kettle lead, cut the moulded kettle-type plug off and connected it up to the PSU. It makes it easy to power up or isolate from the inside, and the Bluetooth app means I don't have to open the box to change any settings.That's brilliant insight, thank you! I am always pained to touch my workshop as the previous chap basically had it built and then never so much as put a drawing pin in the structure lol.
Right side of box with front on showing heating air intake
Would it not be beneficial to pipe the heating intake back into the room? Surely it would make the heater a lot more efficient by reheating the existing warm air instead of heating cold air?
When I first ordered mine I decided this was my plan but after researching it's advised not to.
You will get a condensation build up if you recycle the air.
Fair enough, i thought there must have been a reason not to.
Edit: I also measured up my lights - they are 5ft tubes. I don't think I can get LED replacements at a sensible budget, but I have since learnt they aren't all that inefficient (I was thinking they were 10x worse than even a regular halogen). I will stick until I do something grander I think.
Thanks for doing the maths. I will check - but even those numbers alone fill me with confidence. They are on at most an hour a week at the moment (I don't get in there that much at the moment due to new baby) and there are at least 9, maybe 11.Do you know if they are T8 or T5 Fluorescent tubes, and if they are singles or doubles? As you say, even in 2024 these lights can be pretty decent. They can fade over time though. The T5 type are more efficient but the wattage can vary wildly depending what you have. 20 up to 80watts for the higher output ones. Assuming they are each say 54watt single T5 tubes as an example, that would be 750 watts if all powered on. That's about 19 pence per hour. If you spent say 10 hours a week in there with them all on, that's about £8 a month. Obviously if they are 80watt doubles then that number goes up a lot.
I'd recommend LED battens. You will need generally less of them, plus you can get fully integrated ones behind a safe cover. Instant on and instant full brightness without the starter delay.
Haha that's nuts - great info. Hadn't considered that but it makes total sense.If you do change them out, just another thing to be careful about with any workshop lights in case you didn't know - since I know you do DIY and I think I saw a chopsaw in one of your posts - is that in certain scenarios in some installations, fast spinning machinery can look stationery. You know like the helicopter blades vs camera shutter speed thing? Stroboscopic effects. So you need to be really careful of that. Just do some tests to make sure. Very small chance it could happen but just thought I would put it out there.
