Stage 2 - Garage office build
With the new door in place I started on Stage 2 of the project in May this year. A small office for work. I currently have an office in the house but wanted an area that could solely be used for work without any distractions. So I set myself a deadline of the start of the summer holidays to get this finished.
WARNING! I am a complete amateur at DIY so expect to see plenty of mistakes. I learned everything from YouTube and a couple of great projects on here especially
@Matt-Page (
https://forums.overclockers.co.uk/t...ffice-workshop-thread.18932259/#post-34922113) and
@kai (
https://forums.overclockers.co.uk/threads/garage-conversion-office-utility-room.18878076/) I kept returning to these posts to check what they did. Thanks!
I still want a useable garage that I could work in and park my car if needed so went as small as possible (2.4m x2.4) this also meant that I would not have to worry to much about cutting the sheet material
Inspiration for the final result
Tidy up time - Garage before, bit of a mess!
Few trips to the tip and I had a workable space
Moved Gym equipment to the other side, this will be sorted at a later date.
Trip to Wickes to get a load of Studwork CLS Timber - 38 x 89 x 2400mm and started laying out to get an idea of the size.
After ordering an impact driver (best purchase of the project) I started building the frames
I added a damp proof membrane under the walls and wrapped in house wrap (later discovered it is the wrong way round, also unsure if this is needed buy hey ho…)
At this point I ordered a 2nd hand UPV door and window. I needed the door to open inwards into the office which is not ideal but the garage door framework meant it would be impossible to install a outward opening door.
Door and window ordered from
https://uuwd.co.uk/ I had no idea how heavy a door was until it came to moving it!
Now that I knew the size of the window and door I set about designing the studwork for the front wall
Checking the window for size
With the studwork in place I ordered the sheet material
OSB attached to external walls. I like the look and think I will keep it plain. Due to size of office I did not have to do much cutting other than some notches at the top so that it would slot into the garage rafters.
Next job was the insulation. Have to say I did not enjoy this part at all!
Insulation of ceiling was initially going to be rockwool in the ceiling to cut down on costs but due to poor ordering/measuring skill I had 2 left over sheets of PIR so I decided to use this in the ceiling as well. I will lay the rockwool over the top as plenty of room in the eaves and cant hurt to over insulate.
After going through many cans of expanding foam and many rolls of foil tape the insulation was complete and I got the electrician to lay the wires
Vapour barrier installed (felt like I was building a Dexter kill room) and first sheet of plasterboard installed, again was surprised by the weight of these! probably should have got some help but just wanted to get it done.
Damp proof membrane laid down for start of floating floor
50mm PIR for the floor
Floor boards installed with expansion gap. I used a expanding glue which was pretty cool. Think I may have used a bit to much as I had quite a bit of scrapping to do after.
Lower part of plaster board fitted
Ready to start tape and jointing.
Ceiling painted ready for sparky to come in and fit the ceiling lighting and sockets
Sparky back in today to install a new fuse box and the Lights (2 x 600x600 led panels) and 3 double sockets.
As well as the office I had three dual led tubes installed in the garage area and an additional 4 double sockets. It only had a single double socket before
Window installed this evening and its starting to look like an office!
Just need to finish painting the walls and get a floor laid, I am thinking carpet to dampen some of the sound but still undecided.
So it looks like I will be in for the summer holidays but it may not have a door. Bit annoyed as I have built it single-handedly but just can not get the door sitting correctly so will need to call in some assistance from the father in law.
Then I need to think about decorating and adding some colour to make it less sterile
Have had a great time building it, made a lot of mistakes but have learnt a ton.
Stage 3 is to build a work bench storage unit on the side wall of the office
