GB Gromacs Eh?
21 Jan 2006
Edinburgh
Two of my PC's that are the most recent of my "farm" to ask for WU's have downloaded GB Gromacs at 188 points a pop.
Both have advmethods on but a machine (and i just tested another) without -advmethods is getting 3+ times the size of point WU's (Gromacs).. is this just crappy luck or are there a shortage of decent sized WU's at the moment?
One is a 3.4Ghz 1GB RAM etc PC so it's not that they are returning WU's slowly or are struggling..
There aren't a TON of big WUs out there right now but it's certainly not as bad as it was right after they pulled the QMDs. Personally, I find that my P4s get around 200 PPD on the 188 pointers. That's not stellar but it isn't too bad. What sort of PPD do you get, Major?
Hmm... Are you sure that the P4 is using SSE/SSE2 on the Wu? Are you running with -forceasm? Check your logs for the string
Code:
[16:43:24] Extra SSE boost OK.
If that's all in order, perhaps remove -advmethods for the time being?
The lappy sounds about right but the P4 sounds way off, as BTI says, check you are running with optimisations on.
Stan :)
I disabled -advmethods just for this WU
No issues with :
[21:22:12] Writing local files
[21:22:12] Using table 1
[21:22:13] Extra SSE boost OK.
[21:22:13] Writing local files
Got a 2107, 404 in the mean time. Might be one of the reasons the team's output is lower just now.. few people might be in the same boat.
Ta
I've just had 2 2017 404 pointers on my XP2500@3200, they have been the best ppd I've had in ages.
Blue ->
Min. Time / Frame : 23mn 17s - 249.86 ppd
Avg. Time / Frame : 23mn 39s - 245.98 ppd
I'm usualy getting about 150/180 ppd.
I have 3 machines currently churning out no. 2306 (for 188 pts) and as soon as I finish one ... I get another (o joy :(!).
The 364 pointers suit my systems well - those are the best I've seen in a long time. I've been getting 373ppd on a X2 on one core and even 169ppd on my 'old skool' XP 2000+ :cool:.
Blue ->
Seems they obviously like your AMD better my Intel..
Project : 2107
Core : Gromacs
Frames : 100
Credit : 404
-- Intel P4 3.4 Core 2 --
Min. Time / Frame : 1h 20mn 30s - 72.27 ppd
Avg. Time / Frame : 1h 20mn 46s - 72.03 ppd
Going to try a reboot, not been rebooted in 50 days..
Just picked up one of these p2107.. It's running on my slowest rig, but 71 hours is a chuffin long unit for 404 points :eek:
-- Console 3 --
No Min. Time / Frame
Avg. Time / Frame : 40mn 28s - 143.76 ppd
That rig can munch it's way through a 1112 point Double Gromacs in the same time.
Between these P2107 and p2306 they are rearly killing my ppd :(
That is slow 71hrs, ouch.
Has anyone got anything other than GBGromacs in the last 24 hours (with large wu yes and -advmethods on)
Is there any way to check what is available on the servers for BETA WU's?
