GeForce7600GS Problems
5 Feb 2006
My friend has just purchased the card below for his system and I've been trying to get it to work for the last couple of days.
Leadtek GeForce 7600 GS 256MB DDR2 HDTV/DVI (AGP) - Retail (GX-092-LT)
Everytime I run Battlefield 2 on his system its really slow, laggy and jerks a lot on both high and low graphics settings (its just as good with his old 32MB geforce2 Ti)
I have tried the latest drivers(ForceWare 97.02, 2006-11-10) and also tried some slightly older drivers (Forceware 95.97, 2006-10-14).
i now dont know what to try, any ideas? Would it be that its 8x AGP card in a motherboard that is 4x AGP?
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Pentium(R) 4 CPU 2.40GHz
Memory: 1024MB RAM
Page File: 341MB used, 1352MB available
DirectX Version: DirectX 9.0c (4.09.0000.0904)
Card name: NVIDIA GeForce 7600 GS
Manufacturer: NVIDIA
Chip type: GeForce 7600 GS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_02E1&SUBSYS_2093107D&REV_A2
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.9371 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/22/2006 12:22:00, 4527488 bytes
30 Jul 2005
Midlands
sounds like some software related problem. failing all driver re-installs and driver cleaner work his only option is to give it a full format. before you do make sure you have the additional power connector plugged in. the pcie variants of those cards don;t have additional molex power connector since they draw all the power from the pci-e slot.
OP
5 Feb 2006
I went through the help guides on this forum and used driver cleaner but still no results :confused:
The additional power connector is plugged in correctly.
