geil ram and overclocking
Permabanned
19 Dec 2006
ive got to 3ghz on my e6300 however my ram is limiting me, wont go past 1160 mhz which is high for pc6400, on 5-5-5-22, or i can get it to run at 920 on 4-4-4-12
So do i need pc8500 to go higher than 1160mhz ?
if i use the spd higher than 2.50 the system wont post.
Too right it won't post lol...set the sys multi to 2.00 and timings to 5-5-5-15 and make sure vdimm is @ 2.1-2.2v then see what you can get to.
I take it you're on the lowest memory divider available?
That sounds about right for GeIL's PC2-6400, are you also running it at 2.3V. This is the highest GeIL will warrant.
