HD6XX and HD650 (latest version, a lot of people say that the originals were darker sounding) are the same as far as I can tell, a few people seem to think otherwise, I still think to this day the HD600 is the best headphone of their line.
Main issue with HD650/6XX is the effect that pad wear has on the sound, if used regularly...
The big difference that seems to get picked up on the 600 & 650 is the black screen vs white screen. And some YouTubers and people will speak as that of the holy grail as if it makes a massive difference. Same people that tend to comment on the plastic. My hunch is differences are there, but in reality are marginal, or confirmation bias.
Regarding the pads I did read a detailed article on the newer 6x0 pads Sennheiser introduced around 2021. If I remember correctly they have the clear plastic backing but are said to be slightly firmer and were meant to be a tad more durable. All of my 3 models have these. And the replacement pads I bought last year (part. 050635) are these ones too.
So I don't know if the newer pads are different. Sometimes I go weeks between using my 6x0 models so my pads are all still fairly full. My HD 58X are the most used, just because they are great for YouTube and stuff and the pads seem fine. But I do get why people say you need to replace often and know from experience how massive 'pad rolling' and deterioration can have on a headphone.
