Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Given how much butt it's hauled today through London, gotta be on the van for tomorrow.
It's still not showing Evri has it though.
Mine is getting delivered to work....there is someone there until midday but the door gets locked after.Well it's with Evri now, tracking shows it's with local carrier![]()
That adptor situationyou got going on is..... something!They do look cool, shame I have lost all interest in IEMs really the last year or so, probably a good thing I suppose
I've been trying the LCD-5 through the GameSir's DAC and actually, it has slightly better sound than the X9 in bypass mode with them, so clearly the DAC on the controller is doing some factory EQing. There is a lack of bass and absolute loudness, but it's certainly more usable than the bypass mode without HP-EQ on the X9 and I suppose any other amp that has a bypass mode as well. Interesting... The HE1000se from the controller sound superb as previously mentioned, just minus the loudness again but I run the HE in bypass on the X9 anyway as no need for EQ.
Look at this adapter game just to get 3.5mm from the LCD-5 lol:
https://open.spotify.com/track/6sKKaLDc0SGoFSesS1WWD3?si=9269b0a1815b46e3
Yeah tuned outside of my preference would be accurate, but the HE1000se almost perfect out of the box (just bin the pads and that's all) - So if Hifiman was able to do it on a headphone that originally launched at £3000 without needing any hardware profiling to sound good, then so should other brands, unless as you say it's deliberate in order to stand out for whatever reason.
The Susvara sounded great through the AADAC, but it just needed more power to get loud which the AADAC didn't have enough oomph to do, but the sonics were all there as I mentioned a while ago. I don't get the same impression with the LCD-5, this is 100% a conscious decision from Audeze and probably why many prefer the LCD-4 instead of the 5 as well, even if the 5 has the newer construction process for lighter weight and stuff.
On a side note, look at how much airflow restriction the LCD-5 has!
No wonder it sounds so muffled. I wonder if I can open it up and remove the outer grille film... Though that then involves removing the adhesive tape holding the pads on :/
There is an entire thread on headfi where people confirm it doesn't sound great until you add EQ or use an amp that does a similar thing to the tonal range out of the box, so yes the LCD-5 does sound muffled without EQ, which is exactly as I and others have described and even more recently others on reddit have confirmed after seeing my comment about it that they too found the lCD-5 lacking out of the box without any tuning applied.
It IS my kind of sound (just a different flavour) after the PEQ has been applied, again, exactly as I have said in my full comment post. It suits som,e music and not others, just like how the HE1000se suits some music and not others when compared to the LCD.
LCD-5 needs EQ for the most part, this is a fact, it is not a clean transparent sound without it on an otherwise powerful and neutral sounding amp in its bypass mode.
I already know about the auto EQ profiles, and have already been using them as baselines for the ones that sound the best to my ears, then tweaking it to my ears and saving the profile into a slot as a custom profile. I commented on this in the head fi thread pointing out he should have mentioned this capability but does not, his video is obviously also old as he mentions nothing about the additional features that have since been added even after the early firmware updates.
He does infer that everyone hears things differently though, which is correct, and that individual tuning is therefore a must, not tuning to some graph or whatever, tuning to each individual ear, which is exactly what I am/have been doing to get what sounds correct to my ears in my chain, then comparing the others against that result. I am not bothered about anything else.
Not a great pic but got the 505s
Interesting impressions, thank you. Kind of reads as if the HD 505/550 aren't necessarily worth the extra over for gaming over the 560S. For most people anyway.
These should not sound this good for £20. Got the DAC as spare to throw it into one of my many travel kit/bag in case I forget and need it.
They do look cool, shame I have lost all interest in IEMs really the last year or so, probably a good thing I suppose![]()
It is interesting for gaming as though the positional aspect is good the 560/505/550 are not as clean or as wide/open soundstage wise as some of the gaming headsets though the sound quality is much better. Though the 560's sound a bit thin and flat compared to the 505 I'd say it keeps things less cluttered soundstage wise for gaming though the 505 are better for music and comfort.
I was hoping from what some people had said the 505 would be a decent compromise for music and gaming but having tried them I'm not so sure, still early days though.
They look lovely. Absolute bargain. I've said this before but I wish I could get into IEMs. For gaming, particularly on console they make so much sense; can be driven off of anything, lightweight, loads of new releases (too many?) and lots of choice/options. In some ways more interesting than the full over-the-ears market. Perhaps one downside is that I have read you need to be more careful with hearing damage when using them, but I can see the appeal.
