If anyone's interested AdvancedMP3 has just got a load of clearance Fiio stock in, K13's for 145 quid etc.
p.s. they also have the Fiio Warmer for like £180 ! There are a lot of bargains in the sales section.
In Silver, or at least that's all I can see on there. Very nice prices as you say. I need to buy an AM5 motherboard (again) so trying to keep spending down atm.
Given the descriptions; cosmetic damage, accessories missing, box opened; I wonder if some of this is just them selling on Amazon and getting returns?
Oh the warmer, yeah, its not perfect.
Mine has no marks, all bits still there.
I am going to pair it with that, will look forward to see how it sounds!Yep, very cool. As you say definitely bargains to be had. The K13 particularly at those prices is an absolute bargain. I've had a bit of a renaissance with it in the last few days using it as a DAC for the iFi CAN/OTL, or even sometimes just on headphone out for gaming.
They do have an amazon store, its where i bought the EF400 from, so i would assume so.In Silver, or at least that's all I can see on there. Very nice prices as you say. I need to buy an AM5 motherboard (again) so trying to keep spending down atm.
They have Arya Stealth Open Box = £276
FT1 - £79
Arya Organic £373
You will likely find in that case that the K13 has more of the same but improves in areas like stereo image and layering due to the beefier analogue stage, exact same DAC otherwise!
I somehow want to hear this, looks cool as well!
I ended up buying both the K11 R2R and K13 in that clearance sale to compare to the EF400. If I don't like them, I won't make a loss selling them on.
The K11 turned up today, first impressions are that in NOS mode, it sounds much closer to the EF400 in OS mode than it's NOS mode. When I switch the EF400 into NOS mode, it gets fuzzier, and the K11 is just cleaner and can't match its sound. So I guess, as I thought before, the benefit of R2R is that its better when it performs worse. Obviously it doesn't sound better for all music, it all falls to pieces on very busy tracks, but for older tracks that were mastered on systems that were much worse than the super-clean and resolving modern ones, adding back in that extra distortion that was just expected back then helps. I guess it's kind of like playing retro games on a CRT vs a modern high-res LCD.
Or using an upscaler, i.e. Retrotink, OSSC etc. I feel like these modern R2R's are 'shaders' trying to mimic the CRT look.
But I did remember watching a YT review once of the K13 R2R where the reviewer did state it is more a bit more resolving and not as smooth as the Warmer (probably obvious given the Warmers tube-stage). I've only ever run my K13 in NOS mode, because I suspect running it in OS is just going to get very close to a DS DAC in sound and maybe defeat some of the purpose of the R2R bit. I haven't heard other R2R DACs so I'm limited in that regards, but I did a lot of A-B against the burr-brown iFi Zen Signature DAC (V1 - with the voltage quirks & both as DACs only) and it felt like the Zen was as warm and smooth as the R2R. Or at least it was so close that it was nuanced. Certainly the K13 was more resolving and maybe that lack of detail added to my perception. But it wasn't night-and-day difference and goes against the results if you do an internet search on this stuff. I think the K13 had more soundstage though.
Now again if I went to the effort of blind-testing it might be I'd realise some of this is my mind playing tricks, but it does make me think there are more flavours of R2R implementations out there, which I think you allude to. Equally though a lot of the reviews do seem to nearly always use Hifiman Planars, which I don't and that might be some of it too. I mainly use the HD 6x0 and maybe that also limits some of the affects of Fiio's R2R.
