general issue with the rig
13 May 2009
Stoke-On-Trent
hey ,
when i start my pc the gpu does not kick in straight away, but then about 3-4 sec later it boots with full fan speed and does not stop doing this (have a mentioned that it gives me no screen =/)
i have changed my cpu, motherboard, gpu and have tried with one stick of ram with my set, the only thing i have not tried is my psu, do you think it could be this ??? :mad:
so you have no display at all?
have you tried pulling the pcie connector from the card and reinserting it.
is there no display at all?
or is it only during the boot sequence, but comes on when windows loads.
can you hear the windows welcome tune?
try booting without the pcie connector, the graphics card I believe should scream a loud noise alerting you to not enough power.
try booting with just one ram stick at a time, alternate the sticks.
disconnect the harddrive and try booting, if the display suddenly works it should hang on the boot screen due to no disk drive.
no welcome tune,
screams like me getting run over by an articulated lorry
tried the ram sticks too but no luck :/
Do you ever get to the point the pc boots, do have a multimeter to check the voltages on the psu.
