I know there used to be a few around that were up to date, and these would give you a pretty accurate measure of the overall draw of your components (non exact fans, HDDs and such really don't matter as half-one W here and there really aren't going to make a difference.
). I don't know specific websites now however.
My 75-90% statement may be a little out however, just looking at http://www.silentpcreview.com again (very good at showing efficiency for PSU's) the true range of efficiency is probably actually a little lower, however the true draw of a system is usually a lot lower than you expect (as they point out in a review a couple of months ago a worst case system would probably only draw a little over 300W max (unless of course it has 20 HDD's or is majorly overclocked)).
). I don't know specific websites now however.My 75-90% statement may be a little out however, just looking at http://www.silentpcreview.com again (very good at showing efficiency for PSU's) the true range of efficiency is probably actually a little lower, however the true draw of a system is usually a lot lower than you expect (as they point out in a review a couple of months ago a worst case system would probably only draw a little over 300W max (unless of course it has 20 HDD's or is majorly overclocked)).
