Hey guys, currently I am using the 1 stock fan in a push config.
It does an okay job, 34@ idle but! Well over 66 @load with prime 95 blend test.
I saw reviews for the gentle thypoons n they are suppose to be really quiet while the corsair fan is a real leaf blower.
So i just wanted to know, would there be any performance increase by getting two gt 1850rpm in a push pull config?
N also i see that it is a 3pin fan, while the corsair one is a 4 pin, so whats the difference between 3/4 pin fans?
Thanks
Thanks
