Getting both xbox pad triggers to work at same time.
18 Sep 2010
Sheffield
Title says it all really I tried downloading XBCD but that said there was nothing detected.
Using Windows 7 x64
What do you mean? Works fine for me.. as in hold both triggers down in something like GTA IV, you do a burnout :p
Xbox 360? The official Microsoft drivers allow this by default.
Original "modded" Xbox controller? By default it is assigned to one axis in XBCD, which is where the problem lies.
For example:
L would be Y+
R would be Y-
and neutral would be Y0 (zero)
To overcome this, you can try assigning separate axis to the L and R triggers. It should work in theory, but I never bothered trying to fix it.
It worked on Just Cause I could fire both weapons at same time if i dual wielded. But in a game such as rFactor I could not hold down accelerate and brake at the same time, Doing so would cause the triggers to do nothing at all and make the car stop.
