Good advice on the clot.
A 14 is not a molar, it a premolar, so if hat is he tooth coming out it is fairlt far forward, the same molar would be a 16. As for those numbers, tards use them, humans still use ul, upper left and a single digit, anyway.
An option would be to leave the space.
Don't expect it to close when other teeth erupt, you are too old for that to happen with any consistency.
A gold crown as someone posted a picture of is not an option, there will be no root to stick a crown to.
A bridge is an option, using the tooth in front, or behind, or both to span th gap and close it.
A removable denture with a single tooth is an option.
An implant costing 2000 is also an option where a titanium screw is placed in the bone and a crown placed on top after, dont let some gob#}%{} talk you into that unless he has specialist qualifications to place them.
If it is a 14, does it have to be taken out? Can the tooth not be root filled to try and keep it for a few years first? Is it very badly decayed?
