- 1 Mar 2004
- Warwickshire
I had a rear upper molar removed. My wisdom tooth subsequently moved forward and filled the gap!
Same, Did they get a nurse to come and hold your head aswell.... Was very worried, I half expected him putting his foot up on the chair for leverage
Is it on the NHS if so be carefull, if i were you i'd go for another opinion, Why does the tooth need coming out, can you get a Root Canal done?
NHS dentist prefer to have teh tooth extracted rather than give you a root canal, if I were you id try and do what ever you can to keep it.
If he does take it out make sure you have an xray incase later you find out that you could have saved it to sue the dentist.
Are the teeth next to it in good health if so do not get a bridge they'll damage the teeth.If the tooth does come out then save 1500 for an implant.
Very soon you'll be able to have this done http://www.drbicuspid.com/index.aspx?sec=sup&sub=bai&pag=dis&ItemID=305787
#15 isn't second from back, unless you are already missing teeth....
Did you have adult teeth out while young due to high decay rate?
. Thanks for the replies!
