Hi,
I'm having problems getting a good finish when painting some wood doors. I'm using Johnstones Satin paint and (I think) decent brushes.
I've sanded it down, given it two coats of primer then given that a quick sand and applied the satin wood final coat. First coat was bad so I sanded lightly again and gave it another coat but its no better.
Does anyone have any advice or tips on how to get it looking better?
