Getting temps on x1800xt
7 Mar 2005
Wolverhampton
Is there anyway to find my temps of this card? I cant seem to get CCC working, just gives me error. Even with that net frame work thingy installed.
Can i check temps with anything else?
Reason i ask is because when i play wow, the fan seems to be full speed, 90% of the time and its really getting on my nerves.
Cheers.
Thanks, it worked.
Now for the temps. After a few minutes of WOW the temp reached 84c. Idle is about 74c
Is this good/bad/average?
To hot id say, my old x1800 used to idle about 54 and only go as high as about 76 underload, maybe it needs a good clean out as the dust can build up in those HSF's.
LoadsaMoney said:
A bit hot id say, my old x1800 used to idle about 54 and only go as high as about 76 underload, maybe it needs a good clean out as the dust can build up in those HSF's.
The thing is. Ive took it out and couldnt see a single bit of dust what so ever. But sometimes when i boot the pc the fan makes a high pitch disturbing sound. All the screws are tight tho, not sure why? If i have the case open when its making this noise, i can stop it by gently pushing upwards in the center of the fan. But if i leg go again, the noise is back.
