Ghost 7.5 error... help
Mat
Mat
18 Oct 2002
I have a machine with a 40GB master HDD with a single partition which has XP on it and I want to bascially create a backup image of it to a 20GB FAT32 slave drive on the same channel. Ghost does not see the destination drive at all unless its NTFS which, as I understand it, Ghost cannot write to. If I do try it as NTFS I get the following error:
"Not enough room on device for dump headers"
Google doesn't offer much help on this as far as I can see.
I've tried partition to and disk to image and also tried the '-fni' switch when launching ghost and tried it from the command line but nothing works.
Any help would be awesome.
ghost should see a fat32 drive, however it will split the image up into 2gb chuncks.
Can you notjust duplicate the disk for a backup?
I am assuming you have less than 20Gb of data on the 40Gb drive?
Yes, its basically a new install of XP with a few utilities and small programs.
One other thing, I use an XP bootable disc and launch Ghost from that once its booted. When I check the available drives, A: and B: (the CDR as far as I can tell) are deemed local drives but C: is shown as a network drive (D: isnt shown at all).
Can you not make a direct bootable ghost CD?
I use one that just boots dos with the relevant CD Drivers.
You can use a 98 bootdisk from bootdisk.com.
Never had any problems.
Dingleberry88 :- As for using compression I am aware of that. However it's still no good if you have more than 40gb and have no idea what size to expect after compression!
