** GIBBO TAKES OVER SSD!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
It has being a very long time since OcUK was competitive on SSD, I am now going to change that, lets start with a couple of our best selling 850 EVO drives now at pricing that is extremely competitive if not lowest price in UK:
Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU) @ £149.99 inc VAT
Controller: Samsung MGX Controller
DRAM Cache Memory: 512MB
Sequential Read: 540Mbps
Sequential Write: 520Mbps
4KB Random Read (QD1): Max 10,000 IOPS
4KB Random Write (QD1): Max 40,000 IOPS
4KB Random Read (QD32): Max 98,000 IOPS
4KB Random Read (QD32): Max 90,000 IOPS
Reliability: MTBF: 1.5 million hours
Warranty: 5 Years
TBW: 150TBW
Data Security: AES 256-bit Full Disk Encryption (FDE) / TCG/Opal V2.0 Encrypted Drive (IEEE1667)
3D V-NAND Technology and THE SAMSUNG SSD 850 EVO
Samsung’s unique and innovative 3D V-NAND flash memory architecture is a breakthrough in
overcoming the density limitations, performance and endurance of today’s conventional planar NAND architecture. 3D VNAND is fabricated by stacking 32 cell layers vertically over one another rather than
decreasing the cells dimensions and trying to fit itself onto a fixed horizontal space resulting in
higher density and better performance utilizing a smaller footprint.</p>
The 850 EVO is the advanced consumer SSD powered by 3D V-NAND technology that maximizes everyday computing experiences with optimized performance and enhanced reliability.
Optimized performance for everyday computing experiences
Powered by Samsung's cutting-edge 3D V-NAND technology, 850 EVO delivers top-class sequential and random read and write performance to optimize everyday computing. With improved performance thanks to TurboWrite technology the 850 EVO provides not only more than a 10% better user experience than 840 EVO but up to 1.9x faster random write speeds for the 120/250 GB models as well. In fact, the 850 EVO delivers top class sequential read (540 MB/s) and write (520 MB/s) performance in all capacities. This comes with optimized random read and write performance on all QD and improved QD1 and QD2 random performance for Client PC usage.
Reinforcement of TurboWrite Technology
In the early stages of the 840 EVO, Samsung adopted sequential write performance first. With
TurboWrite, write speeds are significantly accelerated during data transfers by creating a high-performance write buffer in the SSD. If a consecutive write operation (i.e. no idle time) exceeds the size of the buffer, the transfer will exit TurboWrite and be processed at ”After TurboWrite” speeds. Once the buffer is cleared, TurboWrite performance will resume. However, the buffer size for TurboWrite is more than sufficient for everyday PC use, and you should experience accelerated speeds for most workloads. </p>
For the 850 EVO, enhanced TurboWrite technology applied to random write speeds up to 1.9x faster for the 120 GB model and 1.25x faster for the 250GB model over the 840 EVO.
Guaranteed endurance and reliability for maximum use
The 850 EVO delivers guaranteed endurance and reliability by doubling the TBW compared to the previous generation 840 EVO backed by an industry leading 5 year warranty. With twice the endurance of a typical NAND flash SSD, the 850 EVO will keep working as long as you do. The 850 EVO guarantees a 5 year limited warranty or 75TBW for 120GB and 250GB, 150TBW for 500GB and 1TB.
Enhanced reliability with improved sustained performance
With enhanced reliability through improved sustained performance, the 850 EVO assures longterm dependable performance up to 30% longer than the 840 EVO with minimized performance degradation. This means you can use it every day when taking care of work or entertaining yourself knowing it will keep performing even with heavy daily workloads over the years.</p>
Advanced data encryption
The 850 EVO provides the same data encryption feature as the 840 EVO does. Self-Encrypting Drive (SED) security technology will help keep data safe at all times. It includes an AES 256-bit hardwarebased
encryption engine to ensure that your personal files remain secure. Being hardwarebased, the encryption engine secures your data without performance degradation that you may experience with a software-based encryption. Also, 850 EVO is compliant with advanced security management solutions (TCG Opal and IEEE 1667). Magician will guide ”How to use security features”. Furthermore, you can erase or initialize data with the crypto erase service with PSID.
Efficient power management for all PC applications
Power consumption affects everyone. You actually save of up to 50% more on power than with the 840 EVO during write operations thanks to 3D V-NAND consuming half the power of 2D
planar NAND.
Plus, whether it’s preserving battery life for longer cordless use or just saving on costs, power management is important. Device sleep signals the SSD to enter a low power state which is vital for ultra-books and other battery powered devices. With 850 EVO’s Device Sleep at a highly efficient
2mW you get longer battery life on your notebook thanks to a controller optimized for 3D V-NAND.
With the 850 EVO you can work and play longer without having to plug in.</p>
Summary:
SATA 6Gb/s SSD for Client PCs
2.5 inch form factor
Samsung 32 layer 3D V-NAND
Samsung Magician Software for SSD management
Samsung Data Migration Software
Was [£169.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Samsung 1.0TB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E1T0B/EU) @ £289.99 inc VAT
Specifications:
Controller: Samsung MEX Controller
DRAM Cache Memory: 1GB
Warranty: 5 Years
TBW: 150TBW
Was [£359.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
This is not a promotional price, this is a price drop which we shall try and maintain as long as possible. :)
Expect more of this to come over coming weeks/months as I get upto speed once again on SSD, it has being a few years.
Damn nice deals. Samsung is a grest SSD brand too and these EVO are top of the line. I'm almost tempted to buy one, but I gotta pay a £400 data retrieval charge today :( It's got me hyped up for next month though, so close yet so far... I'll definitely buy a Samsung SSD. The PRO version is one tier up, but is the performance worth the premium? Especially with these prices.
About time prices started lowering, if anyone can do it Gibbo can ;)
Just need to work on SEO now a quick google search of the SSD doesn't come up with OCUK :(
Good price on the 500gb :)
Few retailers cheaper, but no one I'd really trust to buy from. Nicely beating most of the competition and better customer service.
What happend to lordbarrass?
Because we do not pay google. ;)
But my job stops at buying the product and promoting it, shall leave SEO/Marketing to those responsible for that, only got one pair of hands. :)
I know wasn't expecting or questioning you, just making it known so whoever responsible can up their game ;)
Gibbo just came into Samsung head office, leaving big hole in the door jamb behind, and they offered him to take anything if he leaves in peace. So he got 850 Evos in good price ;-)
Gibbo any chance of a competitive price £380 ish on a Samsung 1TB 850 PRO? :)
