Hi,
For the past year my samba shares were working fine over a 100Mbit network, and I have now moved over to a gigabit switch.
I set up my windows vista client to use 7KB Jumbo Frames, the maximum it would allow. I also used the following command on my linux samba server to set a matching MTU:
ifconfig eth0 mtu 7000
Now, I can ping between the machines fine with <1ms timings, but samba shares take at least 30 seconds to open up/resolve but once it does it seems to work fine, where as before it was instant.
All my network dns settings are correct, I cant think why vista is taking so long to open/resolve a share? Vista syncs in fine at 1Gbps.
And my linux NIC:
EDIT: for some reason i can only ping the linux box, from vista. If i try to ping the vista pc from linux it doesn't go through for some reason, not sure if this could be related to the problem?
Any ideas on how i can fix it?
Thanks
Jack
And my linux NIC:
Code:
eth0 Link encap:Ethernet HWaddr 00:0C:6E:65:99:50
inet addr:192.168.1.20 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::20c:6eff:fe65:9950/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:7000 Metric:1
RX packets:45742 errors:0 dropped:0 overruns:0 frame:0
TX packets:745 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:3341685 (3.1 Mb) TX bytes:143128 (139.7 Kb)
Interrupt:18 Memory:feafc000-0
Thanks
Jack
