Gigabyte 980Ti Problem
28 Jun 2014
Ok so basically i noticed the other day my PC was making a revving noise, so i took of the side panel to have a look and noticed one out of the 3 fans on the card was stopping then starting again but revving up, so i googled it a little and someone suggested a Manual fan curve,
So i installed MSI afterburner and set up a manual curve, 40 degrees 45% fan speed and so on, seemed to eliminate the fan problem however when i looked in the case i noticed the fan wasnt running at the same RPM as the other 2,
I posted on the Gigabyte forum and nobody replied so thought id ask here,
So basically i just wandered if anyone else has had a problem with this or knows whats wrong, things ive tried!
Cleaning the card of dust Etc,
Manual Fan Curve
Any other sugggestions would be great!!
I'll send you a PM so you have my email and we'll try to troubleshoot you.
I can't PM you, please configure it an PM me.
PhonicHD has not configured his/her trust account
If this is your account please login to activate your trust
