gigabyte brix help
4 Nov 2013
hi there, ive just finished putting in the ram and ssd into my gigabyte brix, ive plugged the hdmi cable into it and im not getting any signal to my monitor.
anyone got any ideas?
thanks
esie
You don't mention plugging in the power cable and making sure there's power to the miniscule thing. Can we assume this is done? :D
IS the computer posting or doing anything ?
Is there another monitor output you can try, sorry I know of the Brix but not familiar with it.
Also, which RAM are you using ?
its not posting at all, i spent most of the morning doing a search on the net, and found that im using 1.5v ram, and i need to use 1.35v ram :(
I figured it was probably your RAM as its the only major thing you added to the board, the SSD wouldn't stop the computer from posting, have you tried with just one stick of the RAM you have, sometimes if you can get it to fire up and get into the bios, you can then configure things to your likings and specs.
yea, ive tried with just the 1 stick of ram, any recommendations on what 1.35v ram i should get, ideally want 8gig without spending a fortune
I bought crucial as it was cheapest I could find as well as being reasonably reliable around £30 for 4gb and £55 - £60 for 8gb.
