Well ive had my DS3 mobo for a few weeks now, and apart from one or two things its brilliant.
Well the main problem is..when i overclock (FSB @ 430) when i restart the system, it disables the overclock on its own! So each tiome i turn my pc on i have to boot into the bios every time, and just enable the overclock. the fsb stays the same, but the option for the OC is set to disabled on its own.
Can anyone shed any light as to why its doing this? It nearly always POSTs, but sometimes i dont get a beep, and the screen says no signal..but i have read that eople have set their pcie freq. to 101 or 105 and it has sorted that issue.
This isnt a majour problem, just very annoying when i forget to do it and wonder why my games lag very bad!
Is this a common fault? I think the board is Rev3.3 (if anyone could tell me how to find out id be glad to if it helps) and its on F10 bios.
Thanks in advance
Thanks in advance
