Just installed the board and came across a few issues.
1. When I attach the 12v power for the pci-e slots to the board I am unable to boot. The psu just shutdowns (Enermax Galaxy 1000w) and beeps. According to the manual this means...Power supply abnormal, proctection circuit activated. Connector terminals are short-circuited.
Because this is not my main box I have just installed a cheap Leadteck 7100GS which has no pci-e connector on it. So when I don't plug in the 12v to the board, the system boots. Would that be right for it to fail to boot if the 12v on the board is not required but plugged in??
2. When the system posts, the case speaker goes nuts and according to the DS4 manual it could be either a DRAM or M/B error. The memory modules are 2 x 512MB Geil PC6400 4-4-4-12. I tried each module on its own in all 4 slots and both modules in changes the slots. The speak continues to go nuts, however on boot there are non error messages and the system boots fine in to windows.
Any idea what is going on there? Or could there actually be a fault with the board?
Cheers
Cheers
