Gigabyte GA-890GPA-UD3H dual video output?
1 Dec 2002
Swindon
Hi,
Quick question, can you use both the DVI and VGA outputs on the Gigabyte GA-890GPA-UD3H motherboard at the same time? I'd like to run 2 monitors, but not sure if I need to buy another gfx card for that?
It's a shame you didnt look at the user manual, which I have just looked at here
On page 22 at the top it shows the 'Dual Display Configurations' that can be used on this motherboard.
You cant have dual monitors on the digital connections as Redmint pointed out.
DVI and VGA can be used at the same time no problem as can HDMI and VGA too.
Its a shame indeed.. But I didnt have the manual handy when I thought about it. :)
Thanks for the replies - I'll set up dual display tonight.
