Hi
Cpu , Ryzen 1800X
Gigabyte GA-AX370 Gaming K7
G.Skill : F4-3200C14D-16GTZ
32 GB
3200MHz
Latency 14-14-14-34
everything is working great on F10 Bios, with XMP enabled
But with F20s Bios, With XMP , the Rams only work at 3000MHZ or less
if I exceed that, or keep it auto which should work at 3200MHz, they won't go to those speeds.
they only work at 2133MHz, why is that??
Gigabyte told me that I don't need to to use F20 as long as am using 1800X
and anything more than 2666MHZ consider as overclocking.
I really don't understand that, I though newer Bios should make the mother board more stable and compatible?
so I shall stick to the F10 and wait till one day a new Bios will make them work again with no issues
Or update the Bios and just use my Rams on 3000MHz?
or is there other way to make them work without enabling XMP
Cpu , Ryzen 1800X
32 GB
3200MHz
Latency 14-14-14-34
