What about Precision X roff(if op is running it???), it was dodgy iirc on certain drivers from memory.
Did you downclock both core and memory? My 470, needs both I think. Not home to check!
6. Reinstalled windows 7 because I got a new SSD
Do you still have your old HD with OS intact?
You could test on the previous OS, to rule out any software/system drivers and your new SSD-if it's faulty you would get CTD's as it isn't always the gpu that causes the ctd's.
Same problem has a guy here in germany, he solved it with downclock.
For some Games those clocks arent stable...
But you tried that already, so imho you will have to RMA it, but i wish you good luck, maybe you can solve this, so i can tell the guy here how to solve it maybe.
RMA it, it's a dodgy card. Had the same problem with my 780ti OC and so have lots of other people. Gigabyte really messed up with the 780ti's.
Agreed and looking around, there seems to be many issues reporting the same. Strangely enough, I had a 560Ti OC that did the same and Gigabyte released a BIOS that upped the core voltage a fraction and that was enough to cure it. I am not sure if they can do the same with the 780Ti in truth.
